tech questions in general
this isnt really related to anything im doing. im trying to research to see how much BS some people talk when go to mod/worktheir car.
1) is there such a thing as too low of an idle. example: 400rpms and if so what would be the problems setting your idle so low
2) for example stock tb 55mm and a hi flow polish 55mm tb. any difference?
3) coolant by-pass from the EGR. can it be done on all cars. example being 2000 camaro Z-28. will there be any gains? dis advantages.
4)turning on your a/c and the car dies. what could that be related to?(obvious one, newbies should be able to tackle this one)
just want to hear your responses and ill tell you the story behind these questions. quite hilarious. i'm actually going to show this post to the person i was talking to, so im trying to keep this un-bias.
RE: tech questions in general
i want this un bias. sooner we have the tech questions answered the sooner i can tell the story. just a couple of real responses will be fine. i just want to stick it to this guy hes a moron
Ok, I'll take a stab at it...
1)Low idle is good if your into old hit and miss engines. G-friends dad has one of his 15hp down to around 69rpm. However most V-8's have a very hard time staying running at that low of an idle.
2)Yes there is a difference between the two..probably about $100 for the flow polish. Performance gains would miniscule if any.It may look pretty tho.
3)Coolant by pass can be done on any car that has it. Just unhook the ends and reattach them together without the EGR. Voila- bypassed! Once again, I see no advantages to doing it. Disadvantages would be smog test depending on the local emmisions, for one.
4)I'm assuming the car is at idle when you turn it on???? Could be the A/C idle control not functioning properly. Or if the compressor has been turned upsidedown and is trying to pump oil instead of refrigerant, this would make the belt squeal but probably not kill the engine. Oh yea, super low idle <400.
i know you car guru's think this is a stupid post but its for another persons own good. i like to correct people who are wrong but some people it takes alot to say their thinking.
just think, its one less person that might be talkin out there *** next time your walking down the street and hear people talkin about cars like they think they know what in hell they are talking about!
for a v8 fuel injected car... 400 is too low... our cars like 750-900
tb differance... money... not worth it imo... its just like a cai or a k/n fliter... same gain... diff price
if the car has the egr coolant ****, then sure it can be done... doesnt mean it should be done... ive heard its a slight gain for our 5.0s... but i have no plans on doing it.... ive just heard that gain part... no proof... then again... dont care
turning ur a/c on at idle and the car dying... either ur idle is too low to begin with... or something is wrong/worn out w. ur a/c compressor...
now tell us why ur askin!?!?!?!?!?!?!?!?!?!?!?!?!?!?!!!!!!
a/c on the fox 5.0's need a diode cluster or they will hiccup real bad when at idle and will totally cut the car off when cruising at around 45-55 mph. Been there, done that, also fixed that issue as well.
