(TPS) Throttle Positioning Sensor
Old Aug 28, 2007 | 12:43 PM
89mustangfive0's Avatar
89mustangfive0
Default (TPS) Throttle Positioning Sensor
Hey guys, i had a question. I own an 89 Mustang gt hatch. How would i know if my TPS was no good? What would the car do if it was no good? I think mine is no good. Thanks
Old Aug 28, 2007 | 12:44 PM
WhiteWindsor's Avatar
WhiteWindsor
Default RE: (TPS) Throttle Positioning Sensor
I think it's "no good ". jk. Check the voltage. One lead to a ground and one lead to i think the green wire. I beleive it should be around .95 to .99. I am sure someone knows the correct readings you should have.
Old Aug 28, 2007 | 12:46 PM
89mustangfive0
Thanks for the help buddy
Old Aug 28, 2007 | 12:50 PM
WhiteWindsor
ORIGINAL: 89mustangfive0
I edited my post, dont know if you saw it before you responded.
Old Aug 28, 2007 | 01:11 PM
86GreenMachine's Avatar
86GreenMachine
think its .5-.98
Old Aug 28, 2007 | 01:19 PM
samseed101's Avatar
samseed101
Just check the cover sheet for the TPS report. Simple enough.
Old Aug 28, 2007 | 01:23 PM
89mustangfive0
=) Thanks guys, ill check it in a bit.
Old Aug 28, 2007 | 02:25 PM
89mustangfive0
yeah its set for .998, how would you know if the tps is bad?
Old Aug 28, 2007 | 02:45 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
symptoms may include hesitations while pushing down on accelerator if there were spots on the tps that register opens....simple enough to know you can run a koeo/koer test which will test the integrity of the sensors/system after that you can check the tps ground and 5 volt reference wires to make sure your getting supply to the sensor and after that you can back probe the signal return wire and with a multimeter set on volts slowly open the trottle plate and look for a smooth rise in voltage readings and if it goes to opens in some spots ...you'll know you have a problem.......ARE YOU HAVING A DRIVABILITYPROBLEM WITH THE CAR????
Old Aug 28, 2007 | 04:24 PM
89mustangfive0
I've been trying to time the car at 14 degrees but it won't run right. I set the tps at .998 and when i take off it kind of hesitates a little. when i start the car up the idle bounces a lot. I think that problem is the Idle air control motor though. Thats another story. Thanks for everyone's help reguarding my issueI really appreciate it guys.
