(TPS) Throttle Positioning Sensor
Old Aug 28, 2007 | 05:28 PM
98MustangGT46's Avatar
98MustangGT46
Default RE: (TPS) Throttle Positioning Sensor
ORIGINAL: samseed101
Just check the cover sheet for the TPS report. Simple enough.
[sm=funnypostabove.gif]
Old Aug 28, 2007 | 05:40 PM
Boss_Hotrod's Avatar
Boss_Hotrod
I not sure what wire you should measure but the voltage should be low when the tps is losed (KOEO) and should have a higher voltage 5 or 8 depending on the system used (not sure which it is) when the tps/throttle body is opened (KOEO). Also check your PCV valve, they can contribute to a rough idle.
Old Aug 28, 2007 | 06:12 PM
slickshift's Avatar
slickshift
ORIGINAL: 89mustangfive0
yeah its set for .998, how would you know if the tps is bad?
It won't reach the specs, or it waivers around like crazy
Old Aug 28, 2007 | 07:00 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
you can perform a idle relearn to stabalize the idle but I'd also check for vaccum leaks and clean the maf
Old Aug 28, 2007 | 08:59 PM
billyam87's Avatar
billyam87
Check for vac leaks, make sure you are running high octane gas with the timing. When you are messing with the TPS, throttle closed it should be as close as you can to 1.0V so .998V is the best. Also, when you are testing it have a friend in the car have him press the gas to the floor and make sure that the throttle body opens all the way, dont do it from the throttle body itself. In doing these tests make sure the car is in the "on" position but not running. To adjust the TPS loosen the screws and turn the sensor, you should be able to get it within specs if it is good. Then tighten it.
I thought that my tps was bad when my timing was messed up but i only noticed it at WOT. Now i set my timing to 12*
Old Aug 29, 2007 | 12:05 PM
89mustangfive0's Avatar
89mustangfive0
i re-adjusted the tps to .998 and timed the car to 14degrees for now. it runs alot better. i also replaced the iac. the idle got better, but still kinda jumps so my dad is gonna do an idle relearn. the only complaint i have is i cant really hear the camshaft that well. i have the b303 cam in it.
Old Aug 29, 2007 | 12:38 PM
FivePointOhh's Avatar
FivePointOhh
in limbo
ORIGINAL: slickshift
WTF? yes it will unless your doing it wrong. (when measuring put key to on position)
89mustangfive0
Date 8/29/2007 10:05:22 AM
check vac leaks
Old Aug 29, 2007 | 05:11 PM
89mustangfive0
i'll check for vacum leaks tonight, i hope its as simple as that.
Old Aug 29, 2007 | 05:13 PM
blackout's Avatar
blackout
Yeah, didn't you get the memo?
-Jeff
jwog666
Dec 27, 2021 08:09 PM
mrtrodonet
Sep 19, 2020 03:12 PM
lincolnshibuya
Dec 8, 2015 04:37 PM
Dathan
Oct 5, 2015 05:52 AM
UrS4
Oct 3, 2015 06:23 AM
