didyou install your diff?
Old Aug 31, 2007 | 12:21 AM
redemption's Avatar
redemption
Default didyou install your diff?
did you install you diff or have somone else install it ?
Old Aug 31, 2007 | 02:24 AM
95 droptop's Avatar
95 droptop
Default RE: didyou install your diff?
if your talking about gears, most people have someone else do it.
Old Aug 31, 2007 | 05:31 AM
capri debris's Avatar
capri debris
I did my own (rebuilt the whole rear... all new bearings and races, seals, gears, clutch packs, shims, axles), but I had a buddy there who works at a garage and does them all the time... just in-case I ran into trouble or wasn't doing something right or had a question. Now that I've done one for myself, all the mystery is gone and there really isn't much to it... the next time will be much easier.
Old Aug 31, 2007 | 05:43 AM
HACKGT350's Avatar
HACKGT350
im gunna be learning how to do them very soon as well as rebuilding the trac loc and if you actually take the time to look at it its not all that complicated. but i suggest that you dont do it by yourself if you have never done it before
Old Aug 31, 2007 | 07:26 AM
WhiteWindsor's Avatar
WhiteWindsor
I've rebuilt 3 rear ends. It is not the easiest thing to do. Like capri said once you do the first one the rest are easier. It takes some mech. knowledge and ability. If you dont feel comfortable, get someone to install. Call around and get the best price you can.
Old Aug 31, 2007 | 07:43 AM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
If you've never done it then get someone or pay someone who has....you need to understang such things as pinion depth, backlash, preload and how to set preload on the pinion bearing and not screwing up the crush collar...cause you only get one shot at that then you'll have to get a new one if you screw up and start all over......
Old Aug 31, 2007 | 10:13 AM
Mike 83 GLX's Avatar
Mike 83 GLX
I did my own gears and diff rebuild. Works great, no noise. It was my first one, but I read alot about how to do it and had experienced friends nearby to answer any questions.
Old Aug 31, 2007 | 11:16 AM
67mustang302's Avatar
67mustang302
General rule of thumb, if you have to ask then get someone else to do it. Or at the very least get someone who's done it before(that doesn't suck) to help you
mtgldr
Feb 3, 2024 09:00 PM
67LimeCoupe
Sep 30, 2015 04:46 PM
BOBCATJACK
Sep 14, 2015 02:18 AM
Sep 10, 2015 08:39 PM
