spools
Old Sep 3, 2007 | 01:28 PM
w8less's Avatar
w8less
Default spools
i am looking to buy a light weight spool does anyone have a particular spool they recommend above the others? and the reasons for the choice please
thanks Justin
Old Sep 3, 2007 | 02:08 PM
w8less's Avatar
w8less
Default RE: spools
also any other recommendations for the rear end such as axles? how our c clip eliminators beneficial?
Old Sep 3, 2007 | 03:20 PM
primetime5.0's Avatar
primetime5.0
Default RE: spools
my buddy runs a moser spool in his car and likes it, c-clip eliminators are beneficial because if the axle brakes you wont loose the wheel. However instead of using the eliminators use 9in ends as they wont leak like most c-clip eliminators do
Old Sep 3, 2007 | 03:42 PM
ZachW04Stang's Avatar
ZachW04Stang
Default RE: spools
ORIGINAL: primetime5.0
Don't they have a different bolt pattern then 8.8's? Or do you have to cut the 8.8 and weld on part of an axle tube from a 9in?
Old Sep 3, 2007 | 03:44 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
Default RE: spools
ORIGINAL: ZachW04Stang
Yes they have to be cut and the 9" ends welded on.
Old Sep 3, 2007 | 03:46 PM
w8less's Avatar
w8less
Default RE: spools
which is better strange or moser?
Old Sep 3, 2007 | 03:50 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
Default RE: spools
Both are probably equal. Here's a link for the c-clip eliminator install.
http://www.corral.net/projects/deepf...dfrearend.html
Old Sep 3, 2007 | 03:51 PM
w8less's Avatar
w8less
Default RE: spools
thanks bernie
Old Sep 3, 2007 | 03:57 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
Default RE: spools
Anytime bro. I thought I had a link to a 9" end install but I don't. That takes a lil bit more work and by a pro obviuosly.
Old Sep 3, 2007 | 04:06 PM
FullAuto's Avatar
FullAuto
Default RE: spools
If you're going to run a spool, go right for the 33 spline axles. They should be close in price to the 31 spline if not the same. I run all Moser stuff.
