spools
Old Sep 3, 2007 | 04:09 PM
w8less's Avatar
w8less
Default RE: spools
are c clips really going to leak that easily?
Old Sep 3, 2007 | 04:12 PM
w8less's Avatar
w8less
Default RE: spools
hey John IM me i got to talk to you about something
PRO50SC's Avatar
PRO50SC
The Rogue Mod
Default RE: spools
ORIGINAL: Jasperstang308
They do tend to if it's not done properly. I was just over a buddies this weekend, his were leaking.
A lot of care has to be taken when trimming the axle tube and then sealing them.
Old Sep 3, 2007 | 04:41 PM
WhiteWindsor's Avatar
WhiteWindsor
Default RE: spools
Jasper, i have the moser spool and 31 spline moser axles and the c-clip eleminators. You will not have to worry about the 31 spline moser axles breaking. C-clip elem. will leak sometimes regardless of how good the install, If you drive on the street some they will leak occ. But i have no regrets with my set-up. I have about 1k miles on it and the driver side has got a very slight leak, but not bad enough to worry about. You should also get a rear-end girdle, i use a MAC.
Old Sep 3, 2007 | 04:43 PM
w8less's Avatar
w8less
Default RE: spools
also has anyone used aerospace or strange brakes?
what causes them to leak just poor installation? or is it just inevitable? the car will be street driven some.
Old Sep 3, 2007 | 05:32 PM
WhiteWindsor
Default RE: spools
Poor install will cause them to leak. And if you are running a full spool, you know how they do not like much of a turn, well when driving on street you will sometimes have to drive other than just a straight line, so with the addition of the spool it will put more pressure on c-clips, thereby causing them to leak occassionaly.
Old Sep 3, 2007 | 06:04 PM
w8less's Avatar
w8less
Default RE: spools
yes it will be a full spool
Old Sep 3, 2007 | 08:24 PM
primetime5.0's Avatar
primetime5.0
Default RE: spools
thats why I suggested 9in ends, no leaks!
Stone629
The Racers Bench
66
Jun 2, 2016 09:52 PM
SXGT
Aug 31, 2015 01:28 PM
Joe57350
Oct 12, 2005 07:12 PM
92BOOSTED
May 5, 2005 04:36 PM
Slo01cobra
Dec 14, 2004 12:50 PM
