stumble and missing
my 89 is running like crap. i just replaced all injectors hoping it would help but didnt. im having this problem when i rev-up the car or drivin it kind of stumbles and sounds like its missing. i checked my vac lines and have replaced some and they all seem good. any ideas? i was thinking it might be some bad battery cables?
Have you read the plugs to see if they indicate any problems? Are the plug wires damaged at all? Do you see any arcing around the wires when the car is runing in the dark? How many inches of vacuum are you pulling at idle? How about fuel pressure at idle? How's the MAF sensor looking? May be worth cleaning it.
filter and pump are fairly new i have replaced both. the plugs and wires were replaced not to long ago and they are autolite and wires are accell. where should i check the distributor besides cap and rotor.
Check your salt & pepper shakers near the firewall. This was my problem. I'll try and find the link on how to do this.
Here:
http://fordfuelinjection.com/?p=85
Here:
Matt's 95 Stang
Oct 5, 2015 07:16 AM
breaking
Oct 2, 2015 01:27 PM
