Oil Pressure issue
Old Sep 15, 2007 | 01:01 PM
mustang883's Avatar
mustang883
Default Oil Pressure issue
Anyone ever have this problem before?....
Stock 5.0 EFI HO in a fox body
When cold, oil pressure is absolutely fine, middle of the gauge
While driving, will fluctuate between middle of gauge and 2nd tick mark from red on bottom when warm
HERE'S THE PROBLEM. . . .
when engine iswarmat idle, all of a sudden needle will drop right into the red,zero oil pressure(you can feel engine shutter a little too)
if you tap the gas and bring rpms back up, oil pressure returns, but as soon as you let it idle again it drops again. . .
Tried putting thicker oil in engine (20w50) to see if it would help w/ pressure and still does the same thing
-haven't tried an engine flush yet, reluctant to pull engine to change oil pump. . .
Is it worth trying an engine oil flush? What flush is best to use? If flush not worth doing, is there any way to change the oil pump without pulling the motor?
Old Sep 15, 2007 | 11:25 PM
93 LX FiveO's Avatar
93 LX FiveO
Default RE: Oil Pressure issue
engine flush?
before you go throwing money at this... buy yourself a mechanical gauge and new sending unit.
while you're at it, get one for the coolant temp.
both are notorious for giving "misleading" signals to the engines actual state of operation
Old Sep 16, 2007 | 01:34 AM
67mustang302's Avatar
67mustang302
Yeah, get a gauge that doesn't suck. If it is actually low at idle and cruiseand the engine has miles on it, you could just put a high volume pump in it.
Old Sep 16, 2007 | 07:04 AM
slickshift's Avatar
slickshift
Yes, stick a real gauge on it first
Old Sep 16, 2007 | 08:39 AM
Grundy's Avatar
Grundy
very common problem for 5.0's. you can get your mechanical gauge and make sure if you want, but wheni bought my car you could HEAR it had no oil pressure, very commin for a high mi 5.0, lots of oil pressure untill you want to idle
Old Sep 16, 2007 | 04:42 PM
93 LX FiveO
when i first hooked up my mechanical gauge, the oil pressure was dropping to about 22 at idle when warm.
i changed the oil, found no coolant or fragments. i used 5 quarts of 10w40 castrol gtx and 1 quart of lucas oil stabilizer
lowest reading ive gotten so far was 38 psi at idle coming off the highway after a 2 hour trip.
its an expensive oil change but it will keep the motor going longer. the lucas stuff works well in our cars.
Old Sep 16, 2007 | 04:54 PM
ZachW04Stang's Avatar
ZachW04Stang
Its the stock gauge don't trust it. Mine bounces around at idle and cruising steady. When I hooked a mechanical guage up, oil pressure was perfect and steady. It would probably be a good investment into a good set of aftermarket gauges.
Old May 16, 2008 | 12:07 AM
drhoward's Avatar
drhoward
Penis Mod Erator
Hey sorry to bump an old thread but I am having the exact same issues with my car right now
I just swapped out my old oil pressure sending unit for a new one and I am having the same problems.......I can't really tell if the car has no pressure at idle by the sound because the thing is so damn loud at all rpms[8D]
Anyone have any advice? I don't really care to install a set of gauges in this thing, is there a way to tell the actuall pressure without installing a new gauge?
Old May 16, 2008 | 01:52 AM
67mustang302
Get a gauge designed to read hydraulic pressure, just a simple mechanical, and d/c the sender and screw the gauge/line into the engine, you can at least see what it is at idle, and with someone helping you can check pressure vs rpm.
Old May 16, 2008 | 10:51 AM
drhoward's Avatar
drhoward
Penis Mod Erator
I don't think I would be able to fit a pressure guage in there, its awfully tight
Is there any other way?
