Still Missing
Old Sep 22, 2007 | 09:28 PM
chosen1_39's Avatar
chosen1_39
Default Still Missing
Still missing, I've added Sea foam to gas for treatment , changed plugs, wires,rotary, and disturbutor cap, changed oil and everything, andsuggustion.
Old Sep 22, 2007 | 09:43 PM
HACKGT350's Avatar
HACKGT350
Default RE: Still Missing
make sure you plug wires arent crossed over one another the spark will travel from one wire to another and cause a miss fire
chosen1_39's Avatar
chosen1_39
this only happen when I'm putting load on it, like when I put it in gear, it is a 5 speed trans, 87 5.0
Old Sep 22, 2007 | 09:53 PM
chosen1_39's Avatar
chosen1_39
this was happening before I changed my plugs , the car set for abour 7 yrs, I finally got her running, I also cleaned the trottle body, its also fuel injected.
Old Sep 22, 2007 | 09:56 PM
HACKGT350's Avatar
HACKGT350
hmm i dont know thats all i can think of you might have a bad fuel injector put a prob light on the injectors while the car is running and see if its firing fuel right
Old Sep 23, 2007 | 12:19 AM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
I f the car sat for a long time it could have a sticking valve or broken valve spring?? I'd run a compression test first to see if there are any major differences between cylinders and then if all checks out....you could perform a cylinder leakage test to see if valves are sealing tight.....also inspect all wire harnesses to injectors ...when a car sits for a long time expecially outside, rodants like to make bedding out of the wire harness
Matt's 95 Stang
Oct 5, 2015 07:16 AM
Dathan
Oct 5, 2015 05:52 AM
breaking
Oct 2, 2015 01:27 PM
ThatJuanStang
Sep 25, 2015 08:01 AM
