Door Panel Removal
Old Sep 23, 2007 | 02:17 PM
5.0stang94's Avatar
5.0stang94
Default Door Panel Removal
Wondering how i should go about removing the door panels in my 94 gt, I have never dont it before?
Old Sep 23, 2007 | 02:23 PM
SOFmech's Avatar
SOFmech
Default RE: Door Panel Removal
Id start by locating the screws that hold it on and unsrew them.
Old Sep 23, 2007 | 03:12 PM
8banger's Avatar
8banger
Just had mine off(replaced the lock cylinder)...pop the window switch up and paneland unplug it...should be a screw(phillips) on the panel behind it....remove the lock ****..push up from the bottom on the panel..has severalplastic hooks that keep in on the door...pushforward and remove over the door handle...mach 460 ..you mighthave to remove the upper tweeter...
Old Sep 23, 2007 | 05:14 PM
mojopony's Avatar
mojopony
Ihave to pull my door panel too. The driver's side window doesn't want to go all the way up anymore.
jerrytubes
Oct 23, 2015 12:11 PM
b8checker
Oct 8, 2015 12:55 PM
jrrhd73must
Oct 2, 2015 09:17 PM
b8checker
Sep 30, 2015 07:11 AM
