bfg drag radial vs. nitto drag radials?
Whats better the bfgs or the nittos. Hooking up and also tire life.
Is it a good idea to remove the front sway bar on a 92 5.0. I am going to put skinnies anyway so is there any problem with that. I did it on my 65 with no problems? Thanks for any info.
RE: bfg drag radial vs. nitto drag radials?
The BFG hook better than the nittos but i believe the expected life out of them is around 5000 miles. The nittos last a lot longer at a max of 15,000 miles but dont hook as well. People still run pretty good times with Nittos though, and they are good in the rain as well.
ORIGINAL: OnyxCobra
I've tried both of them, and can't say i was pleased with either of them, i used the g'force's, and did the longest burnout at the track u could think of with 8 lbs and still spunn all of first, junk tire, mt radials are much better than both. I have had the best luck with the mt radials.
why arent mickey thompsons a choice? they hook better then the two, and they last prty decent... ive had them on all race season, and ive driven quite a bit on them... they still have alota tread left too
but out of your two choices go bfg...
and no swaybar is fine... i run soft front springs, no sway bar, soft *** struts, and skinnies... and daily drive the car... no problems
just for the fact the car is a daily driver and once in a while it goes to the track. wanted to make sure after putting on tires, we wouldnt have to get new ones a couple of months later.
ORIGINAL: 1965mustangman
Nittos will for sure last longer, but they are not as grippy. I am going to try MT's on this one.. but if your looking for tread life in a drag radial nitto is the way to go.
Nittos=longest lasting, least amount of traction(of the 3)
BFG's=not as long lasting, better traction.
M/T's=equal tread wear to the BFG's and the BEST of all 3 on traction...
Ask me how I know.......
nmra1965
Other Professional Racing
09-26-2015 10:46 AM
09-08-2015 11:50 AM
