need help
Old Sep 24, 2007 | 08:29 PM
suzukispeeder's Avatar
suzukispeeder
Default need help
Just traded my Honda civic 2 my brother in law fot a 93 lx 5.0. He put a twin turbo kit on it last year but the turbos where bad so he took them off and returned to stock. He had 2 guys work on it to fix timing issues. The first guy had the distributor 180 degrees off the second guy fixed it and had it running. The only thing was it was sluggish in midrange. Ok heres the question he let it sat for a year after this and now I cant get it to start it turns over but nothing happens, and I dont know nothing about a mustang so does anyone have any ideas on where to start?? thanks for all help
Old Sep 24, 2007 | 08:30 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
Default RE: need help
Well have you checked it for spark and fuel? If it's been sittin that long, the gas is most likely no good also.
Old Sep 24, 2007 | 08:31 PM
5.0stanger's Avatar
5.0stanger
Check for fuel and spark. Listen for the pump to turn on when you turn the key to the run position.
Old Sep 24, 2007 | 08:35 PM
Bullitt94's Avatar
Bullitt94
Agreed to both.
Old Oct 1, 2007 | 08:20 PM
suzukispeeder
ok got it started after changing out the fuel pump. While it was cold it reved up fine, but by the time I got in it to drive it it was missing like sumptin awful anyone have any ideas. Also plan on changing starter because it wanting to grind a bit, and was wanting to put a better one on it anybody have any suggestions. I want sumptin that will turn with more power.
Old Oct 1, 2007 | 08:24 PM
stang8689's Avatar
stang8689
Check timing, plus i'm sure it needs a good tune up, did you change the fuel filter
Old Oct 1, 2007 | 08:42 PM
suzukispeeder
yea replaced fuel filter when i changed out the pump, and got some plugs im going to put on it has new msd wires on it. I just hope its the timing and nothing else
Old Oct 21, 2007 | 07:50 AM
suzukispeeder
well finally tore it down yesterday and figured it out. Bent intake valve on cyl. #2, and bent exhaust valve on #4. The only thing I didn't understand is that cyl #4 valves and combustion chambers looked like they had been washed compared to the rest of the cyls. I don't think a bent exhaust valve would cause this any ideas.
By the way thanks for all the help I really appreciate it.
