Top End Rebuild???
Top End Rebuild???
Ford hasa rebuild kit that has gt 40 heads, cam, cobra upper and lower plenums, timing chain. rockers, etc... for 2,000, my plans are to supercharge it, good price or can i get it better for a lil cheaper else where???
RE: Top End Rebuild???
That seems like a good price when you add up what ever thing would cost seperate. If you bought some used stuff it would save you a couple hundred dollars. Used rockers,intake, and heads could save you $500.
its an alright kit but i think if i was spending 2000 dollars i would wnat abetter intake than a cobra and i would want a different cam than what comes with that kit it is the e cam and where i have seen it it is usually $2149 and for $2249 you can get a trick flow kit thats better but still not worth the monehy in my opinion hpiece a kit together and make the most out of the package because you seem like your gonna run it n/a for a while and you can make a big difference in power over that kit for not much if anymore money if you are stuck on alum heads and hhget more power for less money with cast heads
Dragonus18
09-09-2015 01:21 AM
