firing order
Old Oct 6, 2007 | 08:42 PM
ERock88's Avatar
ERock88
Default firing order
hey, i have a 88 mustang GT. I did a intake manifold gasket, had coolent leak. Now it will turn over and not start. It did run fine before i tore it apart. I am going to check all the electrical connections in the morning and the vacume lines. And i need to make sure i have my wires correct, so im looking for the firing order, and were to start on the distributor. also, on the passenger side of hte motor, there were 5 electrical connections that would fit into the 4 injectors, how would i test and make sure i have the right ones pluged into the right places.
thanks
Old Oct 6, 2007 | 08:49 PM
HaV's Avatar
HaV
Default RE: firing order
the injector wiring should be easy to tell.. just straghten it out.. they should fall in order.
hope that helps
Old Oct 6, 2007 | 10:33 PM
r.barn's Avatar
r.barn
The picture of the above distributor is WRONG for the 5.0
The sequence is right, but all the numbers need to be shifted counter clock-wise one position.
Common mistake, even seen it printed that way in a Chilton or Haynes book before too.
It will run that way, but your injector timing will be slightly off.
Old Oct 6, 2007 | 10:59 PM
HaV's Avatar
HaV
ORIGINAL: r.barn
Wow. your right.. never really paid attention to the placement on the distrib on that pic just the order.. oops.
Old Oct 7, 2007 | 12:24 AM
w8less's Avatar
w8less
good eye r.barn i just noticed it as well
Old Oct 7, 2007 | 07:36 AM
ERock88's Avatar
ERock88
is there anything else i should check? how about fuel, after cranking should i smell fuel or not so much?
Old Oct 7, 2007 | 10:31 AM
ERock88's Avatar
ERock88
what about timing. i had to take the distributor out, how would i make sure i get the distributor back in the same spot? if i were to have jumped a gear on the cam where it drives the distributor would that make timing off? im just about possitive i have gas, i know i have spark, but its just not firing. Just turns over and when i stop turning over it backfires a lil bit.
Old Oct 7, 2007 | 12:21 PM
ERock88's Avatar
ERock88
well i got her all, what do yall run for advance? im at like 13 right now. I have a mild cam along with edlebrock alm heads and intake. what would you suggest for timing?
Old Oct 7, 2007 | 02:01 PM
HaV's Avatar
HaV
13 isnt bad.... about 18 is as high as you can go without pinging though.. I would bump it up to between 15-18, see how it does with high octane gas then drop it if necessary
Old Oct 7, 2007 | 02:04 PM
ERock88's Avatar
ERock88
alright, well i run 93 or what ever premium is as it is just because, so ill try that.
