biggest tires???
biggest tires???
hey guy's i need a little help, im going to be buying a set of 15 by 8 weld wheels for the back, i want a 28" tall tire, but i dont know how wide i can go?? this is a stock length rear axle, an i do have drag springs. I want to go with a set of Mickey tompson et streets, is there anyone else i should look at? also would i need to roll the fender? thanks for the help guys
RE: biggest tires???
What is the backspacing of your rims? That will determine a lot. I ran 28x11.50 15's on an 8" rim w/ 5.5" backspacing. No problems on the outside, I had to slightly massage the inner wells w/ BFH. It wasn't a big deal. If you ran a 10" tire, you would probably be ok w/o having to do anything
ORIGINAL: kweb288
is that with the stock length axle assembly??? and does it stick out a lot?
kweb288 yes it is the stock length axle. I also attached a pic so you can see that it doesn't stick out too much.
Hope I could be some help. If you have any more questions just ask.
ORIGINAL: PRO50SC
ORIGINAL: black_92
ORIGINAL: kweb288
