any mechanics?
your probably trying to take it off at the ball joint....just use an impact if ya got one!!!! three blasts on the ingersoll will cure all!!!!! I usually take off the two bolts that hold the spindle to the strut if there are no camber adjusting bolts and it's fixed
im thinking he can take those two bolts out... and should be able to move it enough to knock the half shaft out, if not and the ball joint has to come apart... well... hit that bolt w. the impact... then the BFH comes in handy...
ORIGINAL: mjr46
I have to go to my friends houseto get a camera after I eat, so I can have pictures of what im stuck on later tonight..
ok i THINK i know what you mean... hard to remember it w. out seeing it... so everything is taken apart? as far as bolts and alll, but its jsut not coming undone? seriously... its time for the 3 or 4 ft pry bar, and the hammer....
