Pushrods....
Old Oct 13, 2007 | 05:40 PM
neonmarine's Avatar
neonmarine
Default Pushrods....
What pushrod length is needed for Ford Racing/Crane 1.7 ratio rocker arms?
Old Oct 13, 2007 | 06:47 PM
OnyxCobra's Avatar
OnyxCobra
Default RE: Pushrods....
Usually the correct answer is you need to measure with a pushrod length checker. If you say what heads you're using someone might be able to give you an estimate.
Old Oct 13, 2007 | 06:50 PM
5.0stanger's Avatar
5.0stanger
They are a direct bolt on for the most part, you should be able to use your same pushrods if you aren't changing heads.
Old Oct 13, 2007 | 07:15 PM
neonmarine's Avatar
neonmarine
Thats what I thought. I installed them and started it. After about a minute, it started backfiring in the muffler. Very softly in the cans. I think instead of the pushrods being wrong I swaped the #1 and the #2 plugwires. I had to drive 20+ miles and the car was popping like a popcorn maker. Does that sound right?
Old Oct 13, 2007 | 07:30 PM
OnyxCobra's Avatar
OnyxCobra
That's definitely not right.
Old Oct 13, 2007 | 07:50 PM
neonmarine's Avatar
neonmarine
They are stock heads. Will it run with two plugs crossed?
Old Oct 13, 2007 | 08:41 PM
OnyxCobra's Avatar
OnyxCobra
ORIGINAL: neonmarine
quite possible, I've seen it before. shouldn't have much power though.
Old Oct 13, 2007 | 08:46 PM
neonmarine's Avatar
neonmarine
I did notice a lose of power. I had to pull fourth up a hill that usually can take 5th. I'll swap the wires tomorrow and see want happens. Thanks for the help. How did you do your rocker install?
Old Oct 13, 2007 | 10:33 PM
5.0stanger's Avatar
5.0stanger
Did you just bolt on the rockers or did you check your preload? Sounds not right for sure. Crossed wires could be really bad, but that could make a back fire.
Old Oct 13, 2007 | 10:58 PM
OnyxCobra's Avatar
OnyxCobra
I installed my rockers when I did the new heads.
