Pushrods....
Old Oct 14, 2007 | 05:48 AM
Gary H's Avatar
Gary H
Default RE: Pushrods....
You should have got some shims with the rockers. Did you make sure they had the correct preload or just bolt them on? Check the wires 1st, then look at the preload.
Old Oct 14, 2007 | 08:09 AM
5.0stanger's Avatar
5.0stanger
http://www.fordracingparts.com/downl...M-6564-All.pdf
Old Oct 14, 2007 | 09:37 AM
neonmarine's Avatar
neonmarine
Guys, thanks for all the help. I just went out and swapped the wires. She's purring smooth! To answer all you questions, I did zero lash and torqued them correctly. I had to shim 3 or 4 I think. I am mechanically able to follow the directions, so it was driving me up a wall. I kept thinking that I did nothing wrong. I had to be something simple. Well, there you go.
I am very familiar with DOHC and SOHC Neon motors. And distributerless ignition systems. I've done it all with those motors, rebuilds, head swaps, cams, turbos, nitrous, and complete tear down rebuilds. I'll start getting more aquainted with pushrod mechanics. Thanks again!
Old Oct 14, 2007 | 09:48 AM
Gary H's Avatar
Gary H
Well... there's your problem... to many spark plug wires, you got lost after the 1st four
Good that it was a simple fix.
Old Oct 14, 2007 | 09:52 AM
neonmarine's Avatar
neonmarine
lol!!
solareclpse2000
Feb 25, 2010 03:42 PM
CrazyCobraSpeed
Apr 26, 2007 12:42 AM
Ninety5five0
Feb 15, 2006 07:31 PM
