Engine seal kit?
Is there a kit that has all of the seals that need to change in a 91 GT 302HO? I'm going to be pulling my engine this weekend and while it's out, I'll be doing some cleaning and I wanted to change all the seals...
ORIGINAL: AdderMk2
dont bother with the felpro gasket kit you get at a local part store... ill re-post in a few with a full list if the gaskets you SHOULD run
mind you I have a 94 cobra, so some of my selection will vary from yours.
Head gaskets $31.96
#9333 PT-1 x2
Valve Cover gaskets - Molded rubber with steel core $28.98
#VS 13264 T
Intake manifold gasket set $25.98
#MS 95952 (I think the regular 5.0 set is MS 95953)
Timing Cover Gasket Set (includes water pump gasket) $9.98
#TCS 45449 (may be different for a foxbody)
Oil Pan Gasket $28.88
#OS 34508 R (molded ruber with steel core)
The only other thing you need is a rear main seal. my block already has one installed, so i didnt need another
Head gaskets $31.96
#9333 PT-1 x2
#VS 13264 T
ORIGINAL: AdderMk2
