HOLY MOTHER#*@^$*%@*# Clutch Quadrant/Pedal Problems
ORIGINAL: AdderMk2
only took me half an hour to change mine AND my cable
Ok now the next question is,
Do you screw the firewall adjuster all the way out to start adjustments or all the way in......
I am having a helluva time getting the freeplay right with a BBK quadrant and firewall kit.
Thanks
Thanks
ORIGINAL: txjason1
Thanks
Thanks
yea benefit of a metalinstead of a plastic. my plastic one snapped in half and shaved the teeth off all at once while taking the pawl with it.
ORIGINAL: 86 5.0L
well thats the thing I started mine halfway and the pedal was WAYYY to high and wasnt disengaging, put it in about 2/3 in and its drivable still slips though so my adjuster is pretty much all the way in [&:]
ORIGINAL: txjason1
Thanks
Thanks
Oh and the problem I had getting the adjusting paw off was the spring holding it on. I went through the hole in the firewall and pryed mine off also
there must be some major differences under the dashboard of the fox, compared to the SN-95.. there wasnt SQUAT in the way when i took mine out... it just slid right off
ORIGINAL: PRO50SC
Did you shave off the 4 lil tabs on the cable where it goes into the fire wall adjuster? The cable end will not slide inside the adjuster w/ those still on it.
also I took the spring off from underneath with a flat-head screwdriver, just the damn pawl refused to come off
the next day, not even 30 seconds with a crow bar and the fu*ker just slide right off
