Boost on SD
Old Oct 18, 2007 | 07:24 PM
shawnk007's Avatar
shawnk007
Default Boost on SD
Can you run boost on a SD car? Cuz you would still have correct vacuum until you went full throttle.......
Old Oct 18, 2007 | 09:01 PM
dimebag's Avatar
dimebag
Default RE: Boost on SD
theoretically, since it gets its a/f maps from the map sensor you would think you could... obviously you'd need a map sensor that reads boost as well... then again youd need more then a 19 lb injector, which the stock comp cant deal with... so negative ghost rider
nitrous on the other hand....
Old Oct 18, 2007 | 09:22 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
well, there is another option but kinda costly on a learning curve perspective for the novice....you could use a Megasquirt tuner set up ...I've read alot about these in recent days to try and understand it's theroy of operation...and sounds like a good deal for speed density tuning if you have the patience it takes to put one together and learn the program and different tuning tables
Old Oct 18, 2007 | 10:18 PM
86 5.0L's Avatar
86 5.0L
SD > MAF
Megasquirt is definatly the way to go if you plan for some serious mods down the road
jwog666
Dec 27, 2021 08:09 PM
TCStangerv6
Oct 11, 2015 05:57 PM
Oct 7, 2015 07:02 PM
2015Ecoboost
Sep 17, 2015 01:48 PM
angeljoelv
SVT Forums
Sep 10, 2015 09:12 PM
