Cant believe i fell into this deal.....
RE: Cant believe i fell into this deal.....
My dam dial up is having trouble getting pics up....and yes i got if for cheaper than what they were asken kuz i know the guy so he cut me a deal.....(thanks to pro for fixen the gap....Ok here we go.....As mentioned above...Trickflow h/c/i(rockers etc), 75mm throttlebody and maf, 42lb. injectors(misake thought they were 30), elecric fan, msd ignition, ford racing 9mm wires, bbk equal length headers,bbk o/r h pipe,2.5 flows and tailpipes, subframe connectors, aluminum driveshaft, 3.55's, ram clutch, 245/40z/r17-Front 275/40z/r17-Rear(11 inches wide) Cobra replicas, fiberglass cowl hood, fiberglass doors, 31 spline ixles, rear end support, motor has been blue printed and balanced at 7,000 rpms, lower contol arms, underdrive pullies....got more receipts comen for suspension work and some other things..... the tires on there now are wasted and it ran a 12.5, got new tires on it, hope for it to hook and get better time, and i know it will run faster but i dont see it hooken a whole lot better....guy told me it dynoed at 380 horses, before he added some other goodies so im not for sure what its got now, have to run to the dyno over here and get it checked out.....and ya you guys are right sounded to good to be true to me also, just one of them things you get lucky with. Ill get these pics up by sat. for ya and let me know what you think....Im sure you will like.
Wtf, thats pathetic, 15 grand into the car and it runs 12.5. Something has got to be ****ed up with the car. it doesnt take much to get it to run that. my friends car ran with gt40p heads, rpm II intake, and a trickflow stage 1 cam with 1.7's and barely any suspension done to it.And why call bull**** on the 380 horse. Thats not that much, especially without a blower. With 15 grand into it it should have more, and with that much i would imagine its a good hci swap. hell a 331 with trickflow r intake, afr 185's, and a custom cam will run 11.5's and its not even close to the cost in the car. if it actually has all that in it than you got a deal on it but it should definately be quicker. Those injectors are over kill for it imo.
