subframe question
Old Oct 25, 2007 | 02:04 AM
jtmustang's Avatar
jtmustang
Default subframe question
hey i know there was just a post on this but i just got one question
i was holding mine up tonite(upr full length) cause my neighbor is gonna weld them up for me tomorrow.they dont sit flat down on the front side of the connector they touch in the front but then slowly get farther away towards the back just curious is this how they go if any one had any pics of their full length's installed?. thanks
Old Oct 25, 2007 | 02:18 AM
OnyxCobra's Avatar
OnyxCobra
Default RE: subframe question
Do they bolt up? Mine didn't lay perfectly flat against the frame until i bolted them up, as i tightened the bolts it snugged them up nice against the frame all the way down.
Old Oct 25, 2007 | 09:11 AM
FivePointOhh's Avatar
FivePointOhh
in limbo
Old Oct 25, 2007 | 09:31 AM
FivePointOhh
in limbo
ORIGINAL: jtmustang
you may have to force them into place with some jacks or something, we have to do that slightly with mine, but it was because the geometery of the connector was slightly off. we compared them when we saw this issue with another set at our local speed shop. but its all fixed now.
Old Oct 25, 2007 | 09:46 AM
jtmustang's Avatar
jtmustang
yeah they are not bolt ins they are weld ins and it looks like yours 5 pointoh are not sitting flat all the way with the subframe
i guess ill try the jack thing can u also heat up the subframe so that i can bend it a little or will that weaken it too much?
Old Oct 25, 2007 | 10:35 AM
ctgreddy's Avatar
ctgreddy
heat it up, bend it, and put it in oil until it cools
and you hardened it.
atleast thats what we do at my work for dies.
Old Oct 25, 2007 | 10:49 AM
jtmustang's Avatar
jtmustang
put in oil huh never heard that before?
Old Oct 25, 2007 | 10:50 AM
OnyxCobra's Avatar
OnyxCobra
ORIGINAL: jtmustang
I know they are weld ins but what i was saying is some bolt in first to get them positioned and then you weld them.
Old Oct 25, 2007 | 10:58 AM
jtmustang's Avatar
jtmustang
yeah i got ya onyx i have the full length weld in's from upr , they fit good except that the front of the subframe does not sit flat against the frame
i dont have any thing at my house to heat them up to bend so ill just have to get them as close as i can with my jack is it bad to really jack the crap out of them tight against the rail?
Old Oct 25, 2007 | 11:54 AM
FivePointOhh
in limbo
ORIGINAL: ctgreddy
its brings carbon to the surface to harden the metal, but it becomes more brittle, if you do it this way....do it only once, otherwise you run the risk of cracking or shattering. those subframes usually have alot of stress they endure.
also when you put oil on it, you either have to drench it in oil or submerge it....otherwise youll have a big nasty oil fire if you just pour a little bit on it or dribble it on there.
