5 lug rear drum alternative.
Ok alot of people (including me) who switch to five lug on their fox body stangs go with the 4 wheel disc conversion for better brakes. Some use the Ranger rear drum conversion. Thing with the Rangers is they are still 9" rear drum no gain other than 5 lug.
Well I had to pull the drums on my Aerostar for the first time to do an emergency repair and I have a set of Ranger rear drum brakes I was going to use for parts. I noticed right away that even though they are based on the Ranger frame they (at least my 89) have larger rear drums, they are a 10" with wider shoes. While I am not sure about the axle length on the Aerostar just looking at the axle is appears they have equal length axles unlike the Ranger but it is a 8.8 rear end the houseing is different from the Ranger and Mustang.
So the Aerostar could be a possible source for a 5 lug conversion or at least a 5 lug rear drum conversion for larger brakes on a Mustang. I do know for sure you can fit factory 5 lug Mustang wheels on one .
[IMG]local://upfiles/66563/DF84FD4248C8479E936A217E70092E0B.jpg[/IMG]
RE: 5 lug rear drum alternative.
Youll need two right side Aerostar axles for a 5 lug swap.
Aerostars use a 7.5 rearend.
You would atleast have to change the backing plate for the brakes along with all the hardware (shoes, etc) for the larger drums.
In reality a 1" bigger drum isnt all that big of a deal and probably not worth the extra work and expense.
The Ranger drums fit right on the Mustang backing plates.
ORIGINAL: raven_ghostwolf
hmm, learn something new everyday
ORIGINAL: Shelty
aerostars are rearwheel drive?
Yes Aerostar is rear drive the Windstar that replaced them is front drive based on the same platform as the Tauras.
ORIGINAL: PJB
Yes you would need the backing plate and hardware to go from 9" to 10" I didn't mention that as anyone with enough mechanical skill to do the swap should be able to figure that out, but I did forget some noobs need that info. True the 9 - 10 isn't that big of a change but you are getting more contact area between the pad and drum surface, not only because of the diameter but the additional pad width.
Like I said earlier this is an alternative for any one that wants 5 lug like the Ranger and maybe can't find a Ranger for parts.
Matt's 95 Stang
10-05-2015 07:16 AM
