need help
Old Nov 3, 2007 | 05:15 PM
loudoo76's Avatar
loudoo76
Default need help
after 10 years of searching/opportunity i finally got a 87 t-top foxbody 5 spd last year, i need help with some slight problems.
1. idle surge, i took off the IAC and cleaned it really good but still does it
2. driver side door has a slight gap with window to seal, somebody told me newhinge pins and bushings should solve the problem, where do i purchase these?
3. driver rear side of car sags down further than the other side...bushings?? i put new struts and shocks and that helped a little.
4. dash pad aboveglove box has a crack, does anyone make a repo for it?
Old Nov 3, 2007 | 09:04 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
Default RE: need help
1.Check for vaccum leaks
2. check ......50resto.com
3.check for a broken spring and or sagged out lower control arm bushings
4. 50resto has them...I installed one on my 85 but the reproduction ones are no where near the quality of the originals...in my opinion they suck ace!!!!...they were flimsy and wavey and the finish/texture was crappy but what do you do?? there is only one company who makes the reproduction ones and they are overpriced for the quality you get[:'(]
