block balancing
if you took apart your short block and put it back together does it need to be sent out to be balanced ? or do you just put it all back together to specs ? or if i was to build an engine new from scratch using stock replacement block crank and pistons would i have to balance it then ?
so what would need to be installed on a new engine before it can be balanced ? oh something else that just popped in my head ... does a new block come with those camshaft bearings in it ?
Matt's 95 Stang
Oct 5, 2015 07:16 AM
