Rear quarter panels
RE: Rear quarter panels
It depends on how much the labor rates are in your area. I work at a body shop and here it is around $55 per hour. Quarter panels usually are about 10-15 hours a piece to install. Thats not including paint and materials.If you are replacing them because of rust, the price goes up because a little rust spot turns into a big one fast, such as when removing the outer panel, all of the mounting areas behind it are also rotted away. A lot of shops will purposely write a high estimate with rust work to scare them away.
is it hard to do yourself though? say redo the inner fenderwells in aluminum then carpet. but i have rot on the outside of my right wheel well. i need to get it off there cuz its gettin bigger n bigger all the time. its right above the tire on the outside.
that's the problem i'm having
except it's everywhere around the wheel well, especially closer to the bottom.
I think I'm going to attempt to repair it myself. I sourced out the quarter pannels and rocker pannels, came to about $500 for both sides. If I do it right I could save myself a couple thousand...
11-10-2015 11:39 AM
wishinsky
09-21-2015 09:48 AM
09-16-2015 07:53 PM
