First steps?
Old Nov 7, 2007 | 06:18 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
Default RE: First steps?
ORIGINAL: 65coupe88hatch
haha ok lemme rephrase that...i want to be able to drive the car in the mean time...im trying to refrane from pulling the motor for awhile tho...dont have the access in the garage right now.. too many projects. how hard is it to swap heads?
easy if you have general automotive knowledge and experience...as for head swap ...you'll be limited to the twisted wedge trick flow head as you don't have valve reliefs in the 86 pistons...of course you could use other heads and stay with the cam you have but I reccommend a cam swap with the heads but your limited on that with speed density without a stand alone tuner...so I'd leave it alone until you can match a decent combo together or you'll just be doing patch work performance[&:]
Old Nov 7, 2007 | 07:20 PM
dimebag's Avatar
dimebag
sd is fine... no one stays sd tho... im getting a good sized cam... and stayin SD...
i still say spray the car... 100 shot to start
FivePointToTheOh
Mar 9, 2020 10:26 PM
firehorse02
Nov 16, 2015 11:28 AM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
Sep 25, 2015 06:58 PM
TfcCDR
Sep 14, 2015 12:08 PM
