motor mounts, dissapointed
Old Nov 9, 2007 | 10:01 AM
BlackBetty93GT's Avatar
BlackBetty93GT
Default motor mounts, dissapointed
so i put energy suspension polyurathane motor mounts on hopin it would lif my engine up so my header wouldnt hit my steering shaft but it still did so in the end i still had to shim it, so it was a waste in my eyes
Old Nov 9, 2007 | 05:12 PM
greenstreak9205's Avatar
greenstreak9205
Default RE: motor mounts, dissapointed
just shim the mount with washers. should do the trick no problem
Old Nov 9, 2007 | 10:26 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
ORIGINAL: BlackBetty93GT
AHHHHHHHHH HAAA so that's why you were removing the mounts the other night so you must of got that one bolt out by the starter??...I just heated my long tube up in a spot and put a dimple in it...but then again I had no choice as I have a tubular K-member...I also had to put a dimple in the tubular portion on my K-member[:@]...nothing ever fits right..even if the package says direct fit
Old Nov 10, 2007 | 12:18 AM
w8less's Avatar
w8less
what kmember do you have?
Old Nov 10, 2007 | 12:41 AM
bighungrymatt's Avatar
bighungrymatt
that reminds me, I need to shim my motor mounts too
Old Nov 10, 2007 | 03:52 AM
AdderMk2's Avatar
AdderMk2
Banned
ORIGINAL: Jasperstang308
my QA1 K-member ddint fit worth ****. I had to cut my stock lower control arm bolts (the rear bolts) so they would fit properly.
I can't wait till I can afford the AJE racing K-member and control arm set
jwog666
Dec 27, 2021 08:09 PM
baddog671
Jul 26, 2016 01:20 PM
UrS4
Oct 3, 2015 06:23 AM
Explosive
Oct 2, 2015 07:45 AM
logan409
Sep 26, 2015 07:43 PM
