Need project advice please
Old Nov 9, 2007 | 07:54 PM
JH23's Avatar
JH23
Default Need project advice please
i'm looking at starting a project....i'd like a 87-93 LX true 5.0 car......when i get one , it wont matter if the motor and tranny is bad.....i'd like to buy a motor that puts out 400-500 HP....and a tranny that will handle it....what kinda prices am i looking at and what exactly do i need to look for ?
Old Nov 9, 2007 | 08:00 PM
r.barn's Avatar
r.barn
Default RE: Need project advice please
347 stroker long block .............. $4,000-5,000
Stock trans might last for while with good clutch
Tremec TKO600's for about $2,000 will last forever.
Old Nov 9, 2007 | 08:01 PM
capri debris's Avatar
capri debris
I'm in the middle of building a 500 hp Capri right now and I'm going with the Trick Flow upper kit and a 150 shot with a Competition AOD that can handle 550 hp. You could also consider a stock 302 with a nice turbo set up and easily get over 400 hp... and a C4 tranny will take that kind of power no problem. Just a couple of ideas for you.
Old Nov 9, 2007 | 08:03 PM
JH23's Avatar
JH23
ORIGINAL: r.barn
i thought the 347's had oiling issues ?
Old Nov 9, 2007 | 08:04 PM
JH23's Avatar
JH23
ORIGINAL: capri debris
C4 is a auto correct ? I'm wanting a NA 400-500 hp.....i want it to be all motor
Old Nov 9, 2007 | 08:06 PM
nmerrill's Avatar
nmerrill
All motor you are gonna be looking at a larger cube, higher compression, or higher revving. probably not gonna happen with the stock 302 block
Old Nov 9, 2007 | 08:16 PM
JH23's Avatar
JH23
ORIGINAL: nmerrill
man you still around here ?....i figured they would have ran you off by now lol......you think i could get that with a 351 ?
Old Nov 9, 2007 | 08:17 PM
capri debris
Yes, a C4 is a 3 speed auto. And if you want it to be all motor, a 351 with some AFR heads and a good cam will be the best way to go.
Old Nov 9, 2007 | 08:20 PM
JH23's Avatar
JH23
would there be a issue of the wiring or anything if i went from a 302 to 351?
Old Nov 11, 2007 | 09:40 AM
91mm408's Avatar
91mm408
If you want to do something Naturally aspirated, you should really consider a 351 based stroker like a 408 with good heads and a cam. It would still be able to run on pupm gas without problems.. Many have built them and they are streetable and run in the 10's no matter what.. My 408 went 10.70's on motor alone... keep it EFI and with a good tune you will have a little better driveability.. as for a tranny it is really preference.. an Tremec will get the job done so long as you are not gonna spray it, but will allow you to run a better gear and still maintain better highway manners.. otherwise if performance is what your looking for.. a C4 with a "GOOD" converter with likely be more consistant and probably faster, however driveablility does suffer a bit..
Wiring should all be the same..
Jan 21, 2016 01:30 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
Jack Weinmann
Sep 25, 2015 03:59 PM
ThatJuanStang
Sep 25, 2015 08:01 AM
stealth_GT
The Racers Bench
Sep 22, 2015 02:19 PM
