Timing gun question
Old Nov 10, 2007 | 08:35 PM
Mustang1994's Avatar
Mustang1994
Default Timing gun question
I never used a timing gun before and I can't find out how to use it, I know how to find the degree. I just don't know how to set it up to to spark plug.
Old Nov 10, 2007 | 08:49 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
Default RE: Timing gun question
clamp for the plug wire goes on the #1 plug wire and the pos and neg clamps go to the battery make a mark with a paint marker usually white on your balancer..one at 0 degrees btdc and another at 10 degrees btdc and then remove the spout connector and start the car up and rotate the distributor until the pointer is lined up at 10 degrees and go no further than 14 and at that setting I'd run 93 octane if they sell that where you live like here
Old Nov 10, 2007 | 09:08 PM
Mustang1994
Awesome thanks alot!
Old Nov 10, 2007 | 09:11 PM
Mustang1994
Ok I seen the gun, and it has a spring on it, so the spring connects to the #1 plug, and go inside the plug wire also? I would say yea but wana make sure
Old Nov 10, 2007 | 09:15 PM
mjr46's Avatar
mjr46
yeah the wierd lookin' inductive pick up is what they call it clamps around the plug wire completely
Old Nov 11, 2007 | 11:01 AM
Mustang1994
Ok when I advanced the timing, the engine make a loud rattle, is that I didn't use the 93 octane?
Old Nov 11, 2007 | 11:38 AM
WhiteWindsor's Avatar
WhiteWindsor
If your fairly stock, you should not advance timing past 12-14 degree's. How far are you advancing it? Find someone to give you hand.
Old Nov 11, 2007 | 01:34 PM
Mustang1994
I advanced it to 14 degrees, according to the balancer.
Old Nov 11, 2007 | 01:52 PM
jagman454's Avatar
jagman454
I would only advance it to 8 or 10, I'm guessing you dont have a heavy modded engine so I'd just set it at like 10 dont go to crazy.
Old Nov 11, 2007 | 04:10 PM
Mustang1994
Oh wow, so set it at 10, I was told to do it at 14-16. Wierd
