Timing gun question
Old Nov 11, 2007 | 04:49 PM
tmajikman's Avatar
tmajikman
Default RE: Timing gun question
10 is the factory setting, 14 is a good point to set the timing at.
Old Nov 11, 2007 | 04:58 PM
19stang86's Avatar
19stang86
I can go to 16* without pinging and it runs fine just depends on what you got. but i run mine at 14* just to stay safe
Old Nov 11, 2007 | 09:03 PM
greenstreak9205's Avatar
greenstreak9205
you understand that they mean bring it to 14*, not advance it 14* more right
Old Nov 11, 2007 | 09:16 PM
Mustang1994's Avatar
Mustang1994
Ok, didn;t know that. I know on my balancer I see a 0 - 20. BTDC I put it on 10 degrees right now. So I am abole to put it on 14? Because I was getting some wierd loud noise when I out it on 14.
Old Nov 11, 2007 | 09:52 PM
greenstreak9205
just to clarify. you unplugged the little spout connector, started the car, had it at 10* BTDC, then advanced it 4 more * to bring it to 14* and it started to shake/make a noise.[>:] thats kinda odd actually. was this at an idle that it did that or was this on the "test drive" after? because by the way it sounds, it sounds like its pinging/detonating. but i cant see why it would be doin this at an idle like the way it seems you're describing
Old Nov 12, 2007 | 04:19 PM
Mustang1994
I heard the sound, after I took out the plug started it up, set it to 14 degrees, and shut it down, put plug back in, test drove it. And when I punched it I heard the pinging sound at high RPM's.
Old Nov 12, 2007 | 06:27 PM
greenstreak9205
yea that noise you are hearing is detonation. not good at all. i would either put premium in it or back it down to 10*
Old Nov 12, 2007 | 07:05 PM
AdderMk2's Avatar
AdderMk2
Banned
just because your car isnt pinging.. doesnt mean you are getting the best performance
CarrieS
Sep 1, 2015 01:00 PM
GimpyHSHS
Aug 29, 2015 06:30 PM
stormesixx
Aug 25, 2015 09:11 AM
KEM Motorworks
Aug 14, 2015 10:13 PM
ding56
Aug 14, 2015 02:40 AM
