What am i missing?
Old Nov 12, 2007 | 06:52 PM
68CSTANG's Avatar
68CSTANG
Default What am i missing?
Ok I thought I could just remove the AC condensor from the pulley setup and then get a belt for a non-A/C car. So I bought it and the belt rubs against itself above the water pump, right after the tensioner. The diagram shows that the path for a A/C-less 5.0 is the same as with A/C except it just goes straight to the PS pump instead of around the AC condensor. Am I missing something? Is there anything different on non-AC cars? I tried using the search and it brought up "none found." Please help
Old Nov 12, 2007 | 07:01 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
Default RE: What am i missing?
ORIGINAL: 68CSTANG
First of all, it's the compressor, not the condensor. On the non a/c cars, the p/s pump is where the compressor is. Yes, you are missing something, the a/c delete pulley needed to do what you want.
Old Nov 12, 2007 | 07:38 PM
5.0stanger's Avatar
5.0stanger
My P/S pump is located where the compresser would be on your car. You may be able to move you pump up, I'm not sure, but I think the brackets look the same.
Old Nov 12, 2007 | 07:41 PM
notchbackmatt87's Avatar
notchbackmatt87
sorry not trying to hijack your thread here but i dont got ac and my power steering pump is still located down below is this okay ?
Old Nov 12, 2007 | 08:59 PM
5.0stanger's Avatar
5.0stanger
ORIGINAL: notchbackmatt87
Your ac must have been removed. As long as your belt doesn't rub, don't worry it is fine
Old Nov 12, 2007 | 09:00 PM
notchbackmatt87
yeah the belt dose not rub so im going to leave it alone thanks for the info tho stanger very helpful
Old Nov 12, 2007 | 09:54 PM
68CSTANG's Avatar
68CSTANG
Wow Stanger that is a really nice and cleanengine bay! So willthe kits that put the PS in place of the A/C use the belt for a regular, non-A/C car? Thanks for your help
Old Nov 12, 2007 | 10:01 PM
kilgorq's Avatar
kilgorq
It should work with you ps pump in the original location. I have seen it done. Try a shorter belt. I would bet your tensioner is pusing the belt down into the water pump.
Old Nov 13, 2007 | 08:07 AM
Chrisinkw's Avatar
Chrisinkw
i got a relocation bracket for my ps pump and it solved the problem
here it is before
http://pic80.picturetrail.com/VOL212.../288226438.jpg
and after
http://pic80.picturetrail.com/VOL212.../288226434.jpg
Old Nov 13, 2007 | 12:17 PM
blwn93gt's Avatar
blwn93gt
ford racing and other companies sell the relocation bracket that moves the powersteering pump up to where the ac compressor was. i think i might have the complete kit used off of the notch i used to have. then all you need is the short belt for the non ac cars.
Matt's 95 Stang
Oct 5, 2015 07:16 AM
Dathan
Oct 5, 2015 05:52 AM
breaking
Oct 2, 2015 01:27 PM
ThatJuanStang
Sep 25, 2015 08:01 AM
