bad head gasket what to do?
ok so i thought most of my oil leak was coming from my valve cover gasket. i took care of that issue and the car still smokes and leaks oil. i looked at the engine block and its coated with s***. i noticed it was mostly right at the head gasket seam where it meets the block. so i want to do the heads and cam. im going to just get the thumper ported combo for now. thats all i can afford. along with that im going to use either the tfs stage 1 or f-303. which of those 2 should i choose and what rocker ratio should i use. also while i have it out im going to redo the main and rod bearings. any advice while i have it all apart and is there anything else thats recomended while the engine is out. b4 i put it back in i will be replacing the clutch flywheel, preping the engine bay also.
RE: bad head gasket what to do?
The head gaskets don't leak oil.....
Also, I would save a little more and buy a better set of heads, they might be ported and all, but they are still E7's....you will want more. After spending $600 plus on them, you won't be happy.
Unless you have copper head gaskets more then likely they aren't leaking oil. Its probably just left over oil, the lower intake may be leaking, or the valve covers are still leaking.
ORIGINAL: 5.0stanger
i havent cleaned it all off yet. i just redid the valve cover gasket this morning and it was all dry underneath. i know my rear main seal leaks and so does my oil pan gasket, the oil panisnt dripping bad tho. the rear main though is real bad. also the cooling system held pressure overnight.
i was thinking i might just clean the engine block off and start by fixing the oil leaks i know of. rear main and oil pan. while i have the trans out i will be doing the clutch and everything also so hopefully after i get that done maybe i wont have the huge oil leaks.
TfcCDR
09-14-2015 12:08 PM
