Help please
Old Nov 18, 2007 | 02:43 PM
bronxboomer's Avatar
bronxboomer
Default Help please
I have a 88 Stang with a 5.0L the car ran fine till one day it just cut off i was told it was the fuel pump so i had it replaced with a brand new pump which i bought at autozone. After i had my buddy install the pump the car gave a hard time to start up we sprayed starting fuild in the intake and finaly the car started up ran for about 2 hours then shut off and wont start up anymore. I changed all the spark plugs and wires new cap & rotor New Battery. The engine just cracks but wont fire up if you spray starting fuild in the intake it wants to kick over but wont start can someone please give me any ideals on what it can be?
Old Nov 18, 2007 | 02:48 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
Default RE: Help please
Well obviously it's fuel related. When you turn the key on, not to cranks, just to the run position, do you hear the pump energise for 2 seconds? If not, you could have a bad relay, inertia switch or a wiring problem.
Old Nov 18, 2007 | 03:22 PM
bronxboomer
Yeah when you place the key on half way with out cranking the engine you hear the pump runing for a few seconds then cuts off
Old Nov 18, 2007 | 03:35 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
I just re read your first post. Have you checked for spark? I thought you said it would start w/ starting fluid but you said it wants to start but doesn't.
Old Nov 18, 2007 | 03:38 PM
bronxboomer
Yes i checked the coil and there is plenty of spark
Old Nov 18, 2007 | 03:47 PM
1fstlx's Avatar
1fstlx
too bad u dont have a noid lite set to check for the injector pulse while cranking.......................... you might also wanna check computer for diagnostic codes. my old lx hatch ran fine one day, i shut it off and went inside to get something came back out and it wouldnt start. turned out it was the tps sensor
Old Nov 18, 2007 | 04:06 PM
bronxboomer
where is the tps sensor located on these stangs
Old Nov 18, 2007 | 04:22 PM
1fstlx's Avatar
1fstlx
its right on top of the throttle body. has orange green and black wires running to it. cant miss it
Old Nov 18, 2007 | 04:26 PM
bronxboomer
Okay thats the little round black senor with 2 screws holding it in place i found this on autozone.com
http://www.autozone.com/selectedZip,.../selectZip.htm
Old Nov 18, 2007 | 04:30 PM
bronxboomer
I'm alittle confuse i found this senor too at autozone .com
http://www.autozone.com/R,APP267967/...ductDetail.htm
