Torque specs
Old Nov 18, 2007 | 10:28 PM
Ninety5five0's Avatar
Ninety5five0
Default Torque specs
Anyone know the torque spec for valve covers on a 95' 5.0L ?
I could only find the v6 torque specs in the hayness manual.....
Old Nov 18, 2007 | 10:52 PM
OnyxCobra's Avatar
OnyxCobra
Default RE: Torque specs
Just use a ratchet and hand tighten them down nice and snug. Their torque rating is most likely too low to use your torque wrench on them anyway :thumbup:
Old Nov 18, 2007 | 10:57 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
I think it wasaround 7ft lbs??? but I just snug them down and give it a little after that but not to much
Old Nov 18, 2007 | 11:01 PM
dimebag's Avatar
dimebag
yup... valve covers... just "snug"
only thing i really tq down is the bottom end parts, and head bolts... everything else is by "feel" anymore
Old Nov 18, 2007 | 11:03 PM
Ninety5five0
Last time i went a little toooo snug, and bent the shyty valve covers ( 25 $ summit set ) so now they are leaky. I'm gonna replace the gaskets and put my stock valve covers back on before i drive to texas in a week or so....I knew it was something low, but i didnt have a torque wrench at the time...Still dont on that note, but i can get one, i just wanted to get this done soon. But i'm sure the stock valve covers arent going to warp like the cheap assss summit ones did.
I also put rtv on both sides of the gasket, which i hear your only supposed to do one side for gasket movement reason. True ?
Old Nov 18, 2007 | 11:11 PM
OnyxCobra's Avatar
OnyxCobra
Get some good gaskets and don't bother with the RTV.
Old Nov 18, 2007 | 11:30 PM
Ninety5five0
I've had a set of cork gaskets just layin around for awhile, i was just gonna use those. I'm debating on wether or not to spend the extra bones and get the rubber ones ( extra bones are hard to come by these days )
I'm tryin to sell some shyt so i can get front tires and tune up everything before i make my long **** journey to texas from ohio.....Gas mileage vs. 4.10 = 4.10s w/ the KO.
Old Nov 18, 2007 | 11:36 PM
OnyxCobra's Avatar
OnyxCobra
Cork gaskets, if you're gonna use em i'd use some like gasket tack n seal stuff with them, i just don't trust them. These are the ones I went with last winter, no problems as of yet and they're nice and thick so you can tigthen them down good: http://store.summitracing.com/partde...p;autoview=sku
Old Nov 19, 2007 | 12:40 AM
stangman94's Avatar
stangman94
ORIGINAL: dimebag
Ha and the intake manifold I decided to go by feel and I didn't tighten it enough and I had a leak. It took forever to find ending up using a smoke machine 2 find it.
Old Nov 19, 2007 | 02:05 AM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
ORIGINAL: OnyxCobra
Forget about those. Get THESE from 50 resto. They are like the ones that came oe.
