need some help and advice
i just got a new mustang and I dont know much about the fuel injected stuff. I have all the mods written down and I wanted to know about an estimated HP and tourqe for it. If anyone can help please do. Thanks for all who are looking.
Engine is a 30. over HO 302 w/ Keith Black pistons.
Ford racing F303. 512 lift cam&matching valve springs
Ford racing adj timing chain
Ford racing 1:6 roller rockers
93 Colbra GT heads w/port work,ford racing24lb / hr injectors NOT STOCK COLBRA INJECTORS!!!
Miloden oil pump
Power plus upper & lower intake w/ port work
Kirbain adj fuel press regulator
BBK 70mm throttle body& spacer
C&L 76mm mass air & inlet pipe
K&N air filter
new water pump
New radiator
Electric cooling fan
MSD 6a ignition, cap,rotor,wires
BBK shorty headers,crome
Summit off road X pipe
Flowmaster mufflers
Ford racing underdrive pullys,a/c eleminator
moroso 7qt oil pan
Energy suspention motor & trans mounts
Centerforce dual friction clutch & bearing
Hurst short throw shifter
Mossier yoke
Ford racing 373 ring & pinion & trac lock rebuild
all new bearings in rearend
Miloden oil pump
K&N air filter
new water pump
New radiator
Flowmaster mufflers
moroso 7qt oil pan
Mossier yoke
[sm=nxsmile.gif][sm=nxsmile.gif][sm=nxsmile.gif][sm=nxsmile.gif][sm=nxsmile.gif][sm=nxsmile.gif][sm=nxsmile.gif][sm=nxsmile.gif][sm=nxsmile.gif][sm=nxsmile.gif][sm=nxsmile.gif][sm=nxsmile.gif][sm=nxsmile.gif][sm=nxsmile.gif][sm=nxsmile.gif][sm=nxsmile.gif][sm=nxsmile.gif][sm=nxsmile.gif][sm=nxsmile.gif][sm=nxsmile.gif][sm=nxsmile.gif][sm=nxsmile.gif][sm=nxsmile.gif][sm=nxsmile.gif][sm=nxsmile.gif][sm=nxsmile.gif][sm=nxsmile.gif][sm=nxsmile.gif][sm=nxsmile.gif][sm=nxsmile.gif]
yes, i mean it
yes, i mean it
When used correctly it's not hard on things except maybe the clutch. When you say Kieth black pistons are they hyperutectic or forged? If they are hyperutetic I'd stop at 125 but if they are forged you can go as much as 175 with the proper fuel and ignition upgrades. Anything over 125 you should get some colder plugs and retard your timing some. When I sprayed I used a MSD timing retarder that retared it for me when I sprayed so I didn't have to mess with the distributor everytime I wanted to use nitrous.You already have aMSD 6A so the ignition is covered but you will need to run a 255lph pump to be safe in my opinion if you don't already have one. I would also get a rpm window switch to turn the nitrous on and off. Go ahead and try some giggle gas you won't regret it!
