THR 550 HP 347 Stroker Vids...
Well, we just fired up another THR Beast and wanted to share for those looking for some winter projects. We'll have it on the dyno soon and out to test -n- tune shortly after that so stay tuned for results. This one is NASTY!
Here's the build:
1992 Coupe
VIN: 1FACP40E0NF168260
Body:
-1992 Mustang V-8 Coupe (NotchBack)
-Complete Repaint Black Clearcoat
-Black/Grey Interior
-Custom THR Basket Style Roll Cage
-Smoked 6 piece Headlight Kit
-Super Clean Engine Bay w/ All Hidden Wiring
Engine:
-THR Built 347 Stroker 11.25:1 Comp
-Probe Forged Flat Top Pistons
-Probe Forged Rods
-Probe Cast Nodular Iron Crank
-ARP Rod Bolts
-ARP Main Bolts
-Probe Billet Girdle
-Canton 7 qrt Race Pan
-Canton Custom Pick Up
-Canton Dipstick
-AFR 185 cc Alum Heads (Milled to 58cc)
-Custom .750 lift Solid Roller Springs
-Titanium Spring Cups
-Titanium Spring Retainers
-Titanium 10 Deg Locks
-Camshaft Innovations Custom Solid Roller Cam
-Billet Solid Core Cam (.731/.705 Lift, 262/265 Dur, 107 LC)
-7800 RPM Shift Point
-Probe Billet Shaft Rocker Conversion (1.6 Ratio)
-Chromoly Pro Hardened Pushrods
-Comp Cams Pro Link Bar Solid Roller Lifters
-All Felpro Custom Gaskets
-EDL Victor Jr Single Plane Intake
-Precision 28 oz SFI Balancer
-28 oz SFI Flywheel
-Pro Systems Custom Built 780 Carb
-CSR Electric Water Pump
-March Pro Billet Brackets
-March Pro Billet Pulleys
-March Pro Billet Tensioner Kit
[font=arial][size=2]-[font="times new roman"][size=1] [/s
Here's the build:
1992 Coupe
Body:
Engine:
-Probe Forged Rods
-ARP Rod Bolts
-ARP Main Bolts
-Canton Dipstick
-28 oz SFI Flywheel
RE: THR 550 HP 347 Stroker Vids...
That would be correct.
We caged it, rewired it, stuck our motor & trans, aeromotive fuel system, aerospace brakes, wheels/tires, carpet, belts, harness, seats, etc. Now it's a nasty 550 HP 347 from THR!
The old car with our tune on it ran 11.90's on motor here in El Paso at 4500 ft elevation. This THR 347should run 10 flat's on motor all day.
[quote]ORIGINAL: Texas_Hot_Rods
Here's the build:
1992 Coupe
Body:
Engine:
-Probe Forged Rods
-ARP Rod Bolts
-ARP Main Bolts
-Canton Dipstick
-28 oz SFI Flywheel
[font="arial"][size="2"]-[font="times new roman"][size="1"]&
Here's the build:
1992 Coupe
Body:
Engine:
-Probe Forged Rods
-ARP Rod Bolts
-ARP Main Bolts
-Canton Dipstick
-28 oz SFI Flywheel
