vibration when trans shifts
ok got a 95 gt 5.0 aode trans and when it shifts at lower rpm i get a pretty bad vibration from the rear of the car i replaced the rear sway bar with an upgrade from summit (didnt work) just ordered a new trans mount to see if thats what it is. if anyone has any ideas please help. ill post if the new mount works
ha..my 94 aode did that for a little while....right before it took a dump...[:@]....does it ever act up in over drive while driving down the road?...and ya i tried the flushing if n all that..worked for a couple days good as new..shifted crisp again..but then about a week later it did it all over again..
ya definatly get that mount fixed...see if it works..hopefully it does..btw..one good tell if it was the tranny for me..when u take off from a dead stop with the shifter in 1st..does it seem to bounce then...and do the same but put it in second too...both slipped bad in mine n bounced real hard...
no when i shift manually it shifts fine whether powering into it or just and easy takeoff when the damn snow melts and i have some time off of work im gonna put that mount in hopefully that works thanks for the help
well by the sound of it ur better off than i was...mine was rediculus...put it in first ..hammer on it n it just bounced the whole car cuz it slipped so bad..second was the same way just not quite as bad..it was bad enuf tho that a couple times when id be turning onto the highway from a stop sign..id get half way in the turn n it would just slip so id slow down a lot ...which is def not good when thers a car or truck coming..main reason i swapped mine..didnt feel like gettin tboned lol...cuz thats never good
My 93 f-250 do's like a rumbling when it downshifts. No slipping at all. Over a year ago i changed out filter and replaced whatever fluid i lost and it drove perfect untill about a month ago and it's starting to do the same thing. Next, i'm going to take it and get the tranny flushed completely and replace all the fluid and seewhat that do's. When dropping the pan your not losing half the fluid, so i'm hoping with flush and getting rid of all the bad fluid it will make a difference long term instead of only a year. If not right now it's still cheaper to do that once a year than buying a rebuilt one.
ill probly go ahead with a flush and fill even if the mount works cause it seems to be a pretty common problem thanks everyone for the help and i appreciate any info that yall can send my way.
darn the luck wifes not gonna like it though
