Clutch Quadrant??
Question, Stock Quadrant keeps slipping....time for a replacement
I was looking at UPR...but the question is, should I buy the whole kit?
1. Cable, Quad, FW Adjuster http://www.uprproducts.com/shopping/shopexd.asp?id=181
2. Quad, FW Adjuster http://www.uprproducts.com/shopping/shopexd.asp?id=634
*TheQuad is not a triple hook in this one...think it matters?
Some say all I need is the Quad/FW Adjust, some say get the kit....I say, ask the Mustand Forum??
What do you think?
What do you think?
Here is another couple of choices...
http://cgi.ebay.com/ebaymotors/STEED...QQcmdZViewItem
http://cgi.ebay.com/ebaymotors/Musta...QQcmdZViewItem
What do you guys think?
ORIGINAL: 86 5.0L
all you need is the firswall adjuster ad quadrant, unless your OEM cable is messed up dont bother, the aftermarket cables are crap, stick with an OEM cable always
I am sure the double/triple hook provides more flexibility...but do you really think that is needed for a Daily Driver if paired with a FW Adjuster?
ORIGINAL: 86 5.0L
ORIGINAL: CantStopTheFox...
That is what I heard....but if I go that route, do you think that 'Speed release' from UPR (with only one hook) is OK? Or should I go for a double/triple hook with more positions??
ORIGINAL: 86 5.0L
ORIGINAL: 86GreenMachine
True but i here that the ford motorsports adjustable cable is stronger then any other aftermarket cable out there. plus you can adj. your clutch in three ways if you have the qaudrent. cable and FW adj.I have all three and i love em.JMO
We have done a lot of research on clutch cables, buying and testing almost every different cable on the market we could find. We have found after all this investigation, that the OEM Ford Clutch Cables are the best quality cables available. They have a multi-material, layered construction that provides better heat, friction and collapsibility protection than all the aftermarket cables we dissected. With that in mind, we have begun selling all year ranges of factory cables, for those customers that demand a cable that will last.
Yeah, single hook quadrant, non adjustable cable, firewall adjuster. That's what I have from Steeda, works great. I bought one of their cables too b/c mine had almost 160K on it.
junior04
Sep 28, 2015 10:53 AM
ccdguy
Sep 19, 2015 05:20 PM
