smog
Old Dec 24, 2007 | 03:42 PM
nacanitihs's Avatar
nacanitihs
Default smog
ok so my buddy that does inspections at the mobil station told me that mass is doing away w/
all emissions because it is too expensive. or something.
i was wondering since my crossover tube is clogged n e ways. should i just take all the smog stuff off? and how complicated is this to do?
also what exactly does all the smog stuff do? i kno its to reduce emissions. but does it have anything to do w/ mpg? if it is removed will it hurt mpg any or make it better? i kno it shouldnt be much either way im just currious.
thanx everyone
Old Dec 24, 2007 | 04:05 PM
stang8689's Avatar
stang8689
Default RE: smog
Get get rid of it all its just a bunch of extra weight, It won't hurt your mpg
Old Dec 24, 2007 | 07:46 PM
nacanitihs's Avatar
nacanitihs
Default RE: smog
ok so how do i do it.. lol like what needs to be plugged etc.. or if someone could direct me to annother thred that explains it. thanx
Old Dec 24, 2007 | 07:56 PM
djh1121's Avatar
djh1121
Default RE: smog
I'm wanting to do the same thing and need to know what to do.
Old Dec 25, 2007 | 11:30 AM
90_Mustang_GT's Avatar
90_Mustang_GT
Default RE: smog
You can delete your air pump with a delete kit or just run a shorter belt. On the back of your heads you will have a pipe that runs from one end to the other. That needs to be taken off. Most guys say you can plug the hole with a 5/8-11 Course thread bolt. The other pipe that is there runs from your air pump down to your cross pipe, get under there and rip that off and either pinch the pipe shut or plug it off. You will have to plug any vaccum lines you take off. It only take 2 bolts to take off yourair pump.
Old Dec 25, 2007 | 05:46 PM
nacanitihs's Avatar
nacanitihs
Default RE: smog
is that all there is to it? and ill just get a shorter belt. anyone know the size?
Old Dec 26, 2007 | 07:00 AM
90_Mustang_GT
Default RE: smog
Ya its a fairly easy job. and i believe the size is going to be 84.5 ' if youre going to delete just your smog pump. If for some reason that duznt work, you can take your old belt cut it and run the route the belt will be runningand mark it than take it to the parts store, if your unsure just buy a few belts.
Old Dec 26, 2007 | 12:58 PM
nacanitihs's Avatar
nacanitihs
Default RE: smog
alright cool. well maybe on one of the next warmish winter days ill look into doing that. thanx a bunch
Roxon68
Mar 17, 2016 08:13 PM
Teddi
Sep 29, 2015 12:24 PM
rafotree
Sep 22, 2015 03:55 PM
wawagner82
Sep 13, 2015 09:02 AM
J.casone400
Aug 28, 2015 09:33 PM
