Underdrive Pulleys?
Old Dec 25, 2007 | 01:16 AM
cgarray17's Avatar
cgarray17
Default Underdrive Pulleys?
Ive been looking at some pulleys and was just wundering what you all thought about them and if they are worth getting, also i am a little conserned with slowing down the water pump and also wundered if it effected it alot, any info on this would be great.
Old Dec 25, 2007 | 05:07 AM
92cobra's Avatar
92cobra
Default RE: Underdrive Pulleys?
DO NOT get them, they are not worth the trouble!! I have them and there causing me nothing but problems.
Old Dec 25, 2007 | 07:29 AM
98MustangGT46's Avatar
98MustangGT46
ORIGINAL: 92cobra
+1 I had them. I would only get them if 1. You have a 140 alt which you do. 2. If you have a really good radiator and really great electric fans.. My friend has them but he has a huge aluminum radiater and two huge fans.
Old Dec 25, 2007 | 11:17 AM
cheetha94607's Avatar
cheetha94607
installed mine with a 3g alt, no electric fan, and all is ok. bbk
Old Dec 25, 2007 | 11:25 AM
HACKGT350's Avatar
HACKGT350
eh spend your money on something better like real mods
Old Dec 25, 2007 | 11:38 AM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
ORIGINAL: HACKGT350
^^^+1......underdrive pullies to me the cost vs the benifit...really isn't worth it....they only free up hp already there..and I'd debate how much as a single mod on a dyno they really do benifit...some say 8-15 rwhp in tests[&:]..but if they tickle your fancy then go for it
Old Dec 25, 2007 | 01:33 PM
jthorn9's Avatar
jthorn9
The Godfather
I have them, not by choice however, and I have only minor charging problems due to my stereo system, other than that, they're fine, wish I had a regular stock pulley setup though. Oh, BBK BTW.
Old Dec 25, 2007 | 10:04 PM
cgarray17's Avatar
cgarray17
ok thanks for the imput i dot think i will get them because i got a big sound system ans its acting a little weired in the cooling department( im going to flush and try new thermostat) i will just use the money for something else.
Old Dec 25, 2007 | 10:23 PM
ttocs's Avatar
ttocs
I have them in and they are fine. The only time you have charging problems is at idle. my instructions said to bump the idle up 1-200 rpm if needed. I am currently running a large amp to 4 subs and getting ready to double it and hook up another amp for the rest of the speakers. The alt is currently stock although I plan on upgrading when I hook up the other amp.... My system is on my cardomain page if you want to compair it to what you are going to put in.
Old Dec 25, 2007 | 11:22 PM
85GTsleeper's Avatar
85GTsleeper
i have them. no problems except slight charging problem below 1200 rpm like said ^ . i wouldnt spend alot of money on them i got mine for 15 dollars [8D]
