internals
Old Dec 25, 2007 | 04:33 AM
mdavis74804's Avatar
mdavis74804
Default internals
Was gonna go the 347 stroker route but after doing much research i dont think i can afford it. So if i go with http://store.summitracing.com/partde...0B&FROM=MGwhat kind of internals do i need to get my stock motor over 300hp. I have 3.73 gears, bbk 70mm tb, 70mm bbk egr plate, bbk cai, underdrive pullies, bbk shorties, o/r h-pipe, and flowmaster catback exhaust on order. So what suggestions do you guys have for getting this stock 302 over the 300hp mark?
Old Dec 25, 2007 | 04:37 AM
primetime5.0's Avatar
primetime5.0
Default RE: internals
not buying that kit, you can piece together one for cheaper and make the same if not more power
Old Dec 25, 2007 | 06:23 AM
mdavis74804
and what do you suggest if not the kit? And what about internals such as crank, pistons, cam, rollers, rods, etc....
Old Dec 25, 2007 | 09:53 AM
uedlose's Avatar
uedlose
stock crank stock rods with good boltsor a low cost aftermarket rod and the lightest off the shelf piston you can find. 0 deck the block.Call Cam Motion for a cam. stock lifters. and the heads you want with the springs Cam Motion tells you to run. and rev the crap out of it.
Old Dec 25, 2007 | 11:21 AM
mdavis74804
so basically pull the motor and have the deck machined and just change out the pistons, cam, springs? This motor is bone stock and has 120k miles on it. 90 GT
Old Dec 25, 2007 | 03:00 PM
primetime5.0
if it only has 120k does it burn oil? if not just piece together a HCI
Old Dec 25, 2007 | 04:14 PM
uedlose's Avatar
uedlose
No, I would have it bored. and dont forget the heads. if you got the extra cash you should have it balanced to help when you arespinning thecrap out of it.Is this your only transportation? if not get the copmpression up more if you can afford it.they make thin head gaskets now to help also.
Old Dec 25, 2007 | 05:14 PM
primetime5.0
you dont need new internals to make 300 horse
Old Dec 26, 2007 | 06:10 AM
uedlose's Avatar
uedlose
ORIGINAL: primetime5.0
Prime is right. I was just saying how to do it my way LOL I have been wanting to do a high RPM High HP motor for a while. with small CID to make HP you are gone to have to rev it. That why I said good rods/bolts and the lightest pistons you could find. But at the same time you are only looking to make 300 hp/ ok stock rods stock crank make sure the motor dont need to bebored. good set of head and good cam and you are there. Have fun!
Sep 8, 2015 11:50 AM
toastintx64
Aug 29, 2015 05:12 PM
