Connecting Rod side play?
Old Dec 29, 2007 | 11:50 PM
fishermanjesse's Avatar
fishermanjesse
Default Connecting Rod side play?
connecting rod has side to sideplay after the piston was installed and rod bolts torqued to specs is this bad?
Old Dec 30, 2007 | 12:25 AM
67mustang302's Avatar
67mustang302
Default RE: Connecting Rod side play?
That's how it's supposed to be. It gives room for the oil that's coming off the bearings to get out, and provides space so that the rods/crank don't rub each other to death. You can check it with a feeler gauge if you like, the book has a spec for it, but I can't recall exactly what it is.
Old Dec 30, 2007 | 12:26 AM
90lxrider's Avatar
90lxrider
there shouldnt be to much ....a couple thousanths i think
[/align]
Old Dec 30, 2007 | 01:11 AM
fishermanjesse
what if its about .02
Old Dec 30, 2007 | 01:12 AM
fishermanjesse
its slides sideways only when its moves on the piston shim too
Old Dec 30, 2007 | 08:54 AM
Gary H's Avatar
Gary H
Connecting-rod side clearances should be 0.0008 to 0.0015-inch
unit91
Sep 15, 2015 09:53 AM
TfcCDR
Sep 14, 2015 12:08 PM
cbird1177711
Sep 3, 2015 08:43 PM
cbird1177711
Sep 2, 2015 08:51 PM
cbird1177711
Sep 2, 2015 04:12 PM
