Air pump delete???
Old Dec 30, 2007 | 07:38 AM
fb385z71's Avatar
fb385z71
Default Air pump delete???
I have an 89 GT and I am just starting to do some minor changes. I have no plans to build it into a race car but no plans to stay completely stock either. I guess what my question is: If i remove the air pump will it cause me any problems? And what do I need to do with the tubes/lines that plugged in along the air lines? I know I will need to buy a pump delete bracket to stick with the stock belt. But what do I need to do to totaly delete the pump? And do i need to cover up any holes that are now open becaue of removing the air lines? I am not sure I am being really clear on all this, but I hope someone understands where I am coming from, and what I am wanting to do. Thanks for your help.
Old Dec 30, 2007 | 07:57 AM
90_Mustang_GT's Avatar
90_Mustang_GT
Default RE: Air pump delete???
If you want to keep your stock belt than yes you will have to buy the air pump delete kit so you still have a pulley in the stock place. Summit will carry them.There should be 2 vaccum lines for your smog pump. These lines are connected to the air bypass valve and the air diverter valve. These are in line from the hoses that are connected to your air pump. Simply take the vaccum lines off and just plug them. Pull all the rubber hose off that you take off the air pump. These hoses will be connected to 2 metal lines. One is connected to the back of the heads. Runs from one side to the other. Kind of a pain to get to, so be patient. After you get this pipe off you will have a hole in each head that will need to be plugged off. I believeyou will need a 5/8-11 course thread bolt to do this.The second metal line is ran down to your crossover pipe. You will have to get under your car to get this off. After you get this line off you can either plug the inlet for this or just pinch the pipe shut, up to you. Hope this helps.
Old Dec 30, 2007 | 08:28 AM
fb385z71's Avatar
fb385z71
Thanks for the help, sounds like i have some fun times ahead of me with that pipe that goes to the heads. Is it possible to just plug it instead of removing it from the heads? Or is that a bad idea? Again thanks for the help.
Old Dec 30, 2007 | 05:08 PM
90_Mustang_GT
Whether you plug the pipe or the heads, its the same still pluggen it. And no problem, i deleted everything so let me know if you need anything else about it, see what i can do for ya.
Old Dec 30, 2007 | 05:34 PM
nacanitihs's Avatar
nacanitihs
why dont you just get a shorter belt? im sure it will be cheaper than buying the delete pully. and i believe the length is 84.5"
Old Dec 30, 2007 | 05:36 PM
90_Mustang_GT
Very true, but if he wants to stick with the stock belt, have to get the pulley.
Old Apr 5, 2011 | 09:53 AM
49F-1's Avatar
49F-1
Default Removing smog pump from '92 5.0 HO
Sorry to bring up the old subject again but, I'm new to the Forum. I'm building a 49 F-1 pickup for my son's first ride. We stuck a '92 5.0 HO motor with a AOD trans (for driveability). Since we are shooting for a clean compartment, all the extra stuff has to go. I'm asking the experts, if we go with the smaller belt, will we have any issues with the A/C pump and idler pulley. I wrapped a string around the apparent route and the belt will be close to rubbing. Any help would be great.
Old Apr 5, 2011 | 01:04 PM
tohoopty's Avatar
tohoopty
you need a 84.5 inch belt
Old Apr 6, 2011 | 09:07 AM
ProTrickVic's Avatar
ProTrickVic
just turn your air pump into a vacuum pump and get 20hp out of it....course it wont last long but you can always upgrade to a proper vac pump down the road
2007CalSpec
Dec 13, 2020 11:42 AM
9550
Oct 26, 2015 05:01 PM
ctgreddy
Sep 20, 2015 08:35 PM
Camster
Sep 10, 2015 11:18 AM
Webster454
Sep 7, 2015 04:59 AM
