My master plan
Old Jan 6, 2008 | 08:27 PM
Shelty's Avatar
Shelty
Default My master plan
was thinking towards the future....as usual. and came to thinking about what to do to my fox, both the 86 and the 91
after I graduate college and start making good paychecks in whatever agency that I get hired from... ATF, EPA, FBI, State police etc...
I want to build up both of my cars... and get a truck or an S197 or both, doesnt need to be an expensive truck, anything with a trailer hitch and 4x4
now anyway
here is my master plan for both
'91 Convertible
347 stroker
forged bottom end
Full trickflow track heat or street heat top end
dont know what type of cam yet
130 amp alt
Full MSD Ignition system or a megasquirt system
Electric fan and waterpump
solid steering shaft
quick ratio steering rack
MM Coilover suspension kit, like the road and track kit which has everything
tubular K-member
full length subframe connectors
6pt roll cage
viper spec t56 conversion
Spec Stg 2 clutch or possibly a stage 3
5 lug conversion with baer big brake kit
17 inch rims... un decided
255lph Fuel pump
Corbeau racing seats recovered in white leather
aside from rims, visually remain current
little details, I forgot like braided brake lines, stainless fuel lines etc
the plan for the vert is to make a kick *** touring machine that can carve corners like it was on rails, the 1/4 will suffer but thats where the 86 comes to play
'86 LX t-top
347 stroker or a 351 conversion bored out as big as I can go
full top end kit with a 750cfm carb or larger
built C4 with B&M hammer shifter
Built 9 inch with 4:30s
mini tub
Weld pro stars with the widest Mickys I can stick in it with the 9 inch and mini tub
drag shocks with airbag
full length subframes or through the floors, battle boxes
tubular k member, that either uses light weight coil overs or retains stock strut setup
removed sway bar
battery in trunk
manual steering rack
10 pt cage
light weight seats
tin interior
150 shot
4 inch cowl hood
new paintjob, red over black
plan for this car is to build a 1/4 mile monster that can run as fast as I can go or the 10pt cage allows
Old Jan 6, 2008 | 08:55 PM
z24stang's Avatar
z24stang
Default RE: My master plan
Good luck in the future.I have dreams too...
Old Jan 6, 2008 | 08:58 PM
ctgreddy's Avatar
ctgreddy
thats a lot of stuff!
both plans look awesome and very expensive.
but i vote u get a nice f250 powerstroke.
then build ur cars.
Old Jan 6, 2008 | 10:35 PM
Shelty's Avatar
Shelty
ORIGINAL: ctgreddy
then build ur cars.
if I tear apart anything 1st, it would be the '86
the 91 is too clean to tear up right now IMO, its a nice DD right now, could use a lil more oomph, but it carts me around without too much gas consumption...
but this will all take place after I am out of school and making a decent living in my career. and I know both will take at least 1 year or more to complete each, when I get to that point in time... Its not like I'm getting married anytime soon (single, not looking or really caring) or having kids (dont like em)either, so once I am making more money I'll have a decent nest egg to play with...
Old Jan 7, 2008 | 01:24 AM
primetime5.0's Avatar
primetime5.0
I wouldnt waste my money on TF's engine kits, especially on a 347, and putting in a forged bottom end on a stock 302 is a waste of money
Old Jan 7, 2008 | 01:40 AM
w8less's Avatar
w8less
ORIGINAL: primetime5.0
agreed
Old Jan 7, 2008 | 01:43 AM
primetime5.0
and screw s197's!
Old Jan 7, 2008 | 01:49 AM
86 5.0L's Avatar
86 5.0L
https://mustangforums.com/m_1754590/...tm.htm#1754590
[8D]
Old Jan 7, 2008 | 02:01 AM
primetime5.0
damn I need to make one of these threads... im almost done with all my wishes!
Old Jan 7, 2008 | 05:49 AM
92civy's Avatar
92civy
Heres mine:
Engine
*Dart iron block (4.125” bore, 454” stroker)
*AFR 225 58cc chamber
*Custom Grind Cam
*super victor intake
*Forged piston, rods, crank.
*Moroso 7qt rear sump oil pan
*Electric water pump
*March billet brackets
*Hooker 2” Long Tubes 3” collector
*3” Custom X pipe
*Spin Tech 3” Dumped mufflers
*MSD Ignition System
Fuel System
*150 GPH fuel pump
*Prosystems carb
*Adj FPR
Drivetrain
*Redneck C4 transmission
*Custom Stall converter
*SFI Flexplate
*B&M Pro Ratchet Shifter
*Deep transmission pan
*B&M shifter cable
Suspension
*QA1 Front coil Overs
*QA1 Rear Coil Overs
*URP Double Adjustable Upper Control arms
*South Side Lower Control Arms
*Caster/Camber Plates
*Full Length OR Through the floor Subframe Connectors
*4-lug/disc brakes all around
*Greg Weld Drag stars, with slicks!
Chassis[/b]
*12 Point Roll Cage
*1987 Coupe
*Mini Tubs
Differential[/b]
*Fab9 Cromoly 9”
*3.73” Gears
*3.5” Custom Aluminum Driveshaft
