Different smog ?
Old Jan 9, 2008 | 10:44 AM
90_Mustang_GT's Avatar
90_Mustang_GT
Default Different smog ?
So what if you pull your metal pipe off that back of your heads and the hole is not 5/8, what does that mean?
Old Jan 9, 2008 | 11:27 AM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
Default RE: Different smog ?
ORIGINAL: 90_Mustang_GT
what are you trying to do?? delete the air injection??? if so you can pull the tube off but it'll probably be so carboned up the threads will be hard to access unless cleaned well...you can try and run the correct size bolt in or trick flow sells thermactor plugs...which is the system you are working on = thermactor air injection
Roxon68
Mar 17, 2016 08:13 PM
Teddi
Sep 29, 2015 12:24 PM
rafotree
Sep 22, 2015 03:55 PM
wawagner82
Sep 13, 2015 09:02 AM
J.casone400
Aug 28, 2015 09:33 PM
