need your oil knowledge
Old Jan 11, 2008 | 03:19 PM
LOUDexhaust's Avatar
LOUDexhaust
Default need your oil knowledge
It's about time for an oil change on my 91. I got 102k on the clock and have been running the stuff the ford dealer puts in since 97k. So i'm wondering if I should keep using whatever ford uses or if I should get something else. My car doesn't appear to be burning any oil either. And before I get flamed I go to ford because my family works there and its easy. any knowledge is appreciated!
Old Jan 11, 2008 | 03:29 PM
Irish5.0's Avatar
Irish5.0
Default RE: need your oil knowledge
Do you know what weight they are using. I read an article that said a 20 weight was great for the 5.0 because of the spacing in the lower block that these engines created alot of heat. The article went on to say that after a 100k tear down and using the 20w that the main bearings still looked brand new. I definitely wouldn't go with anything under a 10w-40
Old Jan 11, 2008 | 03:36 PM
92cobra's Avatar
92cobra
10w-30 penzoil here for over a year no problems, great compression, great oil pressure, great ride.
Old Jan 11, 2008 | 03:43 PM
LOUDexhaust
I just found out that they use 5w30 semi-synthetic.
Old Jan 11, 2008 | 03:55 PM
1985stang's Avatar
1985stang
Irish50, 20 weight is pretty heavy. Maybe the bearings looked ok, but it puts stress on other things because of the oil pump having to work harder. 10W-30 is a good for these cars.
Old Jan 11, 2008 | 04:12 PM
Mustangkiler's Avatar
Mustangkiler
My stock portfolio would appreciate your castrol purchase.
Old Jan 11, 2008 | 05:05 PM
1985stang's Avatar
1985stang
ORIGINAL: Mustangkiler
Haha, go Mobil 1.
Tivo304
Aug 28, 2023 12:19 PM
wraith777
Sep 28, 2015 10:49 AM
belam
Oil and Oil Related Topics
Sep 23, 2015 11:29 PM
Demodulates
Sep 18, 2015 11:14 AM
