clutch help
Old Jan 11, 2008 | 06:56 PM
2nstable's Avatar
2nstable
Default clutch help
doe anyone have a spec stage 3 clutch in there street car
Old Jan 11, 2008 | 07:32 PM
Tberg725's Avatar
Tberg725
Default RE: clutch help
my buddy has one in his street car but the clutch isWAY overkill for his setup, that clutch is rated at 600ft/lbs and if im wrong im sure someone will chime in and correct me
Old Jan 11, 2008 | 08:54 PM
WhiteWindsor's Avatar
WhiteWindsor
I have the spec stage 3. My car is not a dd, but i do drive it. The clutch is streetable to me. The pedal is soft, with the stage 3 there is no playing with the clutch, when it grabs it grabs. I have a tko-600 but would not want this clutch with a t-5 especially you dont have the power that warrants this kind of clutch. Like i said, you cant finesse the pedal, it's grab and go, and i've heard of the t-5 bellhousing's cracking because of it.
Old Jan 11, 2008 | 09:02 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
if your gonna use as a daily driver you don't need that much of a clutch
Old Jan 11, 2008 | 09:12 PM
92GreyGT's Avatar
92GreyGT
Why wouldn't you want that clutch with a T5? It's a puck style clutch, correct?
Old Jan 11, 2008 | 09:18 PM
WhiteWindsor
Based only from other people's experience with. Yes it is a 6 puck design, you can get a 4 but the 6 is more streetable. I've read complaint's with people using t-5 with stage 3 and since there is no slipping the clutch they said it just put too much stress on bellhousing. Like i stated earlier, you cant ease off the clutch with the stage 3, it just clamps down and grabs. But it is an awesome grabbing clutch, would i want to drive it often with it, probably not.
Edit: The stage 2+ will handle aboutthe same power load anddoe's not incorporate the puck design and is supposed to be much more streetable.
Old Jan 11, 2008 | 09:22 PM
92GreyGT's Avatar
92GreyGT
That makes sence. If you are making power enough to warrant that clutch you should have a blow proof anyway.
Old Jan 11, 2008 | 09:27 PM
WhiteWindsor
Yea, your right. I have the mcleod. I'm not close to the 600 lbs of torque n/a but the juice will be getting me up there.
Thunderball
15
Nov 22, 2015 11:49 PM
junior04
Sep 28, 2015 10:53 AM
MacSerio
Sep 27, 2015 01:05 PM
ccdguy
Sep 19, 2015 05:20 PM
MasterLanMan
Sep 13, 2015 08:21 PM
