Sites for blocks..
Sites for blocks..
So i'm thinking IF I get a 94 95 GT or Cobra, their blocks are pretty weak, so i want an aftermarket block. What's the cheapest block that would be better than the stock block? Or just what are some sites I can go to?
I've searched on google, but can't find really a good site. Thanks.
RE: Sites for blocks..
To safely and run for a long time, at about 400-450 hp. I'm 18 and have the people who can help me make that happen. But I don't want to use the stock block for that hp, it's a ticking time bomb.
i believe almost everyone on here have stock block's ...if you are looking into a aftermarket block your looking at like $1,800+, plus all the machine work....find a 302mexican block if you are looking for something a bit stronger.....they will hold around 650hp
[/align]
400-450 is very very reasonable for the 5.0 block so i wouldnt even bother getting a new one just send the block to a machine shop and get it bored over and have them do a main bore alignment and cam bore alignment and you will be set for 450hp i have some friends that are running 6+ on their blocks with no problems at all
ORIGINAL: HACKGT350
400-450 is very very reasonable for the 5.0 block soI wouldnt even bother getting a new one just send the block to a machine shop and get it bored over and have them do a main bore alignment and cam bore alignment and you will be set for 450hp i have some friends that are running 6+ on their blocks with no problems at all
ORIGINAL: The stang II
What do most people here go with?
Boostaddict
Lethal Performance
10-01-2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
10-01-2015 08:57 AM
